miguelv
November 27, 2013, 9:10pm
1
I am trying to import stl files in vbScript using Rhino.Command "_Import c:\filename.stl"
The problem is that a window “STL Import Options” pops up.
How can I avoid this?
(Besides checking the box “Always use these settings” manually)
Is there a way to access these options through vbscript?
Thanks in advance
Best regards,
Miguel
miguelv
November 27, 2013, 9:16pm
2
Some problems solve themselve:
Rhino.Command “-_Import c:filename.stl _Enter” seems to do the job
To avoid having dialogs pop up, always use the “-” dash version of the command as you figured out. You can then also script in any command line options you need.
–Mitch
John_Brock
(John Brock)
November 27, 2013, 11:09pm
4
Assigned Scripting category
