So I am using this plugin who delivers different geometric forms (polyhedra). The thing is, I can’t separate the faces generated in those forms. I tried to explode but it always says “Cannot explode X single surfaces” and I also tried to move/delete control points which is good so I can workout some forms from the original one, but I wouldn’t be able to give different materials to each surface in a render for exemple. I want to be able to select only one surface so i can work on it separately.
Sorry for bad english, not my mother language and thank you.
