GhPython and Breps
Hello @dale,
I’m trying to get this def to work in GH, but it doesn’t ComponentIndexType or Index for any type of geometry, despite having the correct type hints.
What am I doing wrong?
As an aside, if I have the type hint in the input set to Brep, what is the easiest way to get the GUID? I made a separate input here, but would like avoid this in the future.
Thanks,
Dan
You’re expecting us to re-type your code (and Rhino file) instead of posting it yourself.
Docs for ObjRef.GeometryComponentIndex say “The parent geometry has a component index = -1”. This is what you’re seeing and why GeometryComponentIndex.ComponentIndexType us returning InvalidType.
I haven’t used these methods before, but I believe they are intended to be used when you’re selecting sub-objects from Rhino.
If you want to access the faces, edges, or vertices of a brep why not use the properties and methods of the Rhino.Geometry.Brep class to access them?
Would be helpful if you would post your code and describe what you’re trying to accomplish.
-Kevin
No, I’m not. I just need help understanding how ObjRef can/should be used in GH.
Does this approach even make sense? Or is the another way to access ComponentIndexType and/or Index?
@kev.r
Thanks, that helps a lot.
For what it’s worth, here is the code snippet I was working on earlier today:
import scriptcontext as sc
import Rhino.DocObjects as rd
import Rhino.Geometry as rg
import System.Drawing as sd
import Rhino
doc = Rhino.RhinoDoc.ActiveDoc
objref = rd.ObjRef(doc,y)
print objref.ObjectId
print objref.GeometryComponentIndex.ComponentIndexType
print objref.GeometryComponentIndex.Index
and here is the code I’m using now, which is returning Area, Types, Indices, Loops and Faces
import Rhino
area = x.GetArea()
#pointInside = x.GetPointInside(0.01)
edges = x.Edges
faceList = x.Faces
faces  = []
loops  = []
indices =  []
types = []
for i in faceList:
    faces.append(i)
for i in faceList:
    loop = i.OuterLoop
    loops.append(loop)
for i in faceList:
    index = i.FaceIndex
    indices.append(index)
for i in faceList:
    type = i.ObjectType
    types.append(type)
It is far easier to answer questions when your code and geometry is posted.
@Joseph_Oster got it. Will do.
