How to select a group of curves
Hi Everyone! I have here a set of curves highlighted in Green. These are generated from Termite Nest plug in. I want to select each floor lay out individually just like in the one circled in blue, not as a whole generated table of layouts.
P.S. It is seen in the list panel that each floor layout is listed with 39 indices. I want to select each set that contains the 39 indices
Try the “Bang” (Explode tree) component. But you don’t have much control over it…
It seems like you can simplify the output of your plugin…
2023-11-10 08_19_08-Window
Note:
“Construct path” is useful to construct higher level paths, like a {1;5;3}.
If you have a simple tree with just one layer of depth, you can bypass construct path component and directly use an integer number.
Many integer numbers will let you extract more than one branch.
Hi thank you for this, It is working!
