Hi, here is the image sampler which I just did. How can I make black area of the image to be bigger circles and white area to be smaller circles (reverse the now effects)?
Assuming the output of the sampler is from 0 to 1, then before you do your division, use the subtraction component to subtract the output from 1.
Thank you so much Ethan, problem solved by subtraction component.
