like as shown in front view so when I do this on surface the side objects are getting streched and not as per I have put on the base surface so how can I resolve that thing in rhino???
like in many of my design I am facing this issue also so I need to solve this thing in it.
Your base surface has a different proportion, and your target surface has curved sides, hence you get distortion. If you split it into a rectangular region and two curved “end caps”, you get what you want.
@Lagom@davidcockey
I traied your solution but still the object have to bend only on surface vertically but they are geting strcthed horizontally as well I am sharing my 3dm file here
Also please do not mark solution till the final answer which I meet from the community as I am aware about this and I will mark that solution when I will get proper answer.
I have shared you the 3dm file in which while the objects are there reaching the edge they are getting stratched so main issue is that while the center objects remains proper so how can I resolve that.
Sorry, I don’t quite understand where this issue you mentioned is occurring. Have you opened the model I provided to take a look? If so, could you please take a screenshot and let me know which area’s deformation in this model is unacceptable to you? Thank you.
in the perspective vieew this is showing the curve on which I am trying to bend the object but as you can see in the front view the objects are getting stratched so that is I am asking and in the 3dm file which was shared by you previously has mostly flat shape so that is the main issue that not meet my doubt clearance
In the left image, you can see the objects bend only with the vertical curvature of the surface - because the surface has no curved shape sideways. So, if you do the above, you have no sideways distortion.
This is for the one side surface but I am basically doing stone design so I have to put this all side as well if possible let me know if we can connect for a short meeting online so I can explain my doubt proper to you as I am close to my requirement as per your guideline but not exact that.
because when the shape is like the below image mostly ‘S’ curved so this is the main exect problem I am facing
still if possible let me know if we can connect online
Greeting for the day @jessesn , @davidcockey , @Lagom I tried the solution you have given to me for the flow long surface and that is working fine for that but for another shape as target surface that solution not working for me.
I am not sure that what is the mistake I am doing or I do not know exect step so the object is getting changed after the flow so please let me know exect step to do the same my requirement issue is below for better clearence.
I am creating this design for the stone CNC carving
The issue is I need the same shape without changing the structure and just set on the target surface and in proper shape so not looks abnormal so please help me related to this.
I am sharing the 3dm as well with this. also I have added just single object as the file is limited size so array the same in X direction for this for approx 4 to 5 (just reminder)
