hi all,
im trying to render panels on vray but not sure how to make them read as panels and not as a wall. i extruded my elevation from autocad. any tips on how to make it realistic? do i have to fake the panels, offset them or move them individually? thank you. this is one rough render that i have and i have an image of the desired stone outcome i want. thank you!
insert gaps in between the panels - best is to use an offset towards the inside. extrude those offset panels, that way, when rendering, the gaps will be visible.
Not an architect or such. Will the Rhino Shutline function work here?
