How to push multiple plug-ins within one package.
How should i structure my package folder? Do i need a manifest.yml for each plug-in or one manifest.yml for the whole package?
Can anybody help with this? @will ?
I don’t want to push stupid stuff to the server and the test packages i pushed to the tests server does not show as per-release in the packagemanager so i could test different attempts…
Sorry for the slow response, @seppeldue. Your “version 1” above is the right way to go, if you want to include multiple plug-ins in a single package. There should only be one manifest.yml file in the package and it should be directly in the directory that you call yak build from. The plug-ins should also be in the same directory as Rhino won’t load plug-ins from sub-directories of a package. See “The Anatomy of a Package”.
I did push version1 to the test server and expected it to show as pre-release in package manager.
Maybe it is a good idea to say in the tutorial that the test server does not allow to install packages…
