Hello, I cannot understand in any way as it is possible I use the specified component to pull the panel of curves on a surface which is located above?
Thanks!
Thanks!
Not sure what your desired effect is (if you want to directly project, or just get the curves on the surface). Since you are using the Surface Morph component, I assume you do not want to project the curves onto the surface. Here is how you would go about using the Surface Morph component:
CurvesToSurface.gh (8.9 KB)
This would be the way I’d approach it for polyline curves:
CurvesToSurface2.gh (11.7 KB)
I thank!
