The undo, redo, and delete commands are not repeatable in rhino witch makes so mush sense to me as when hitting enter or the right mouse button repeats the actual commands like split and trim, but save shouldn’t be a command that gets repeated especially when you have a 4GB file and you save it then you accidentally press enter thinking that you will repeat the last command but oops! saving the file again and waaaaaaait till it’s done and wast a lot of time…
any solutions?
thank you so mush!..FINALLY!
