Delete command not repeated?
I need to use the Delete command very often (assigned to a short-cut button) and seems that any time I want to repeat the previously used Delete command, Rhino don’t memorize this command but instead it is using the previously used command.
It is possible to fix this behaviour somehow?
It’s probably in your list of “Never repeat these commands”…
Thank you. This is the trick! Overlooked that part in options.
