i never paid much interest to this accept _MaxViewport and occasionally _SetDisplayMode, which i had added several times, actually believing that it would now be the last time i would have to add it. i first thought this might have occurred due to some freezing of rhino so i intentionally quit rhino now the intended way to see if this command keeps saved.
i think i have this problem for a few versions already. honestly i also cant remember that it ever saved anything added to the list. anybody else seeing this?
Something got unfixed for me, repeating a command after a view change no longer works for me. Used to behave not like this for me.
Tried adding _SetDisplayMode, SetDisplayMode and '_SetDisplayMode to never repeat these commands but none of those commands seem to register to that list.
When you add them to the list? Do they just disappear? What exactly happens when you are adding them in Preferences > General > Never repeat these commands? Do they show up, but when you close the Preferences dialog and re-open it, they do not appear?
Had no effect, in my opinion this should be a standard function though, as you can not repeat changing a view anyway. I often work in wireframe, or shaded to select edges and run a command and see what it looks like in the rendered mode and rerun the same command before SetDisplayMode. I think that worked before, might be wrong though.
