Hi all
I wanna make an Angular dimension on Rhino by Python can anyone help.
Hi all
import Rhino
import scriptcontext as sc
plane = Rhino.Geometry.Plane.WorldXY
center = Rhino.Geometry.Point3d(0.0,0.0,0.0)
radius = 5.0
angle = Rhino.RhinoMath.ToRadians(45)
offset = 12.0
arc = Rhino.Geometry.Arc(plane, center, radius, angle)
ang_dim = Rhino.Geometry.AngularDimension(arc, offset)
sc.doc.Objects.AddAngularDimension(ang_dim)
sc.doc.Views.Redraw()
Hi Gijs,
Is there a script that can dimension an angle as a cut angle. For example -90 degrees from the angle shown using the usual angle dim tool in drafting.
Cheers,
Alan
Hi Dale,
Thanks for the quick response here is a screenshot to explain, I know it’s easy to do the math etc, but some fabricators like the cut angle shown so currently you have to draw a perpendicular line to get the cut angle and I just wondered if there was a way that a script could be written to offer a cut angle option to be displayed in the same way.
Thanks you.
Cheers,
Alan
Hi There, just curious if this was a possibility or just not worth the time. Completely understand it’s a low priority request and a lazy wish.
Cheers,
Alan
