How to make a surface from a mesh?
how to make a mesh from a surface?
Do you mean make a surface from a mesh (looks like that is what you are trying to do from your screenshot)
yes, I want to make a surface from mesh
It’s not always straightforward depending on the mesh topology but if the mesh is like your screenshot then get the vertices of the mesh from the Deconstruct Mesh component and use the vertices as the points in the Surface From Points component.
tried to do so, shows an error
upload your .gh file~
test1.3dm (125.8 KB) Test1.gh (11.3 KB)
You need a U direction count.
I do not know how to do it
thanks a lot
You can use Patch surface
thanks
Can you please edit the title of this thread to convey what you really meant?
Done.
