How to know what the default linetype name is?
I just found that the linetypes listed via rhinoscriptsyntax.LinetypeNames(), omits the linetype ‘Continuous’.
This appears to be the default, hardcoded linetype.
Is there a way to find the name of that default linetype? Is it always Continuous; is it always present in all files?
The issue I ran into is that when explicitly stating linetypes for layers and testing them against the existing linetypes in the document, the ‘continouos’ type is caught as non-existent.
Can someone shed some light on what can be expected so I can write a valid workaround.
Is there somewhere to know the name of the default linetype?
Thanks
-Willem
I think setting the layer linetype index to -1 will set it to default (continuous), but unfortunately, the following doesn’t seem to work here:
import scriptcontext as sc
layers=sc.doc.Layers
index=layers.Find("Default",True)
print layers[index].LinetypeIndex
layers[index].LinetypeIndex=-1
layers[index].CommitChanges()
sc.doc.Views.Redraw()
Hmmm… --Mitch
@Willem, i guess it has no name. If you set a linetype instance to Default(), it is continuous.
@Helvetosaur, below seems to work, strange it uses -1 as index:
import Rhino
def DoSomething():
    # get the layer
    layer_index = scriptcontext.doc.Layers.Find("Default", True)
    layer = scriptcontext.doc.Layers[layer_index]
    # get layers linetype name and index
    lt_index = layer.LinetypeIndex
    lt_name = scriptcontext.doc.Linetypes[lt_index].Name
    print "Linetype '{}' with index: {}".format(lt_name, lt_index)
    # set linetype to continuous (default)
    lt = Rhino.DocObjects.Linetype()
    lt.Default()
    layer.LinetypeIndex = lt.LinetypeIndex
    layer.CommitChanges()
    print "New LinetypeIndex:", layer.LinetypeIndex
    scriptcontext.doc.Views.Redraw()
DoSomething()
c.
