Selection Events, Subobjects - Which one is Selected?
When a user selects a subobject, the SelectObject event fires for the object but I don’t see information for which subobject was actually selected.
How does a plugin determine this?
Example:
Create a rectangle, Curve->Rectangle, Corner to Corner.
Shift-Ctrl-leftclick one edge (say, the top one).
The SelectObject event fires for the entire polyline. How do you tell that a subobject was the actual selection and which one?
I don’t see anything else that looks relevant for events at the same level (Rhino Doc events where the SelectObject one is in the API docs). I also searched for ‘subobject’ in the C# developer examples.
I started this question out looking at 3D objects and simplified to the rectangle for this question.
First public beta of Rhino8.
You can access the selected sub-objects component indices like this:
private void RhinoDocOnSelectObjects(object sender, RhinoObjectSelectionEventArgs e)
  foreach(var rhObj in e.RhinoObjects)
    foreach(var ci in rhObj.GetSelectedSubObjects())
       //code
This is a raw/incomplete implementation via c# script in gh.
It cheks 1. if the selected object is of type Brep, and 2. if it’s a sub-object of type BrepFace, and it adds the face geometry to a variable “geo” to output…
Different cases are not covered.
Note I managed to make it work by using try-catch trick…
Rhino 7.
private void RunScript(bool x, ref object A){
    if(x){
      RhinoDoc.SelectObjects += OnSelectObjects;
    }else{
      RhinoDoc.SelectObjects -= OnSelectObjects;
    A = geo;
  // <Custom additional code>
  Rhino.Geometry.GeometryBase geo;
  void OnSelectObjects(object sender, Rhino.DocObjects.RhinoObjectSelectionEventArgs args){
    if(args.Selected){
      foreach(Rhino.DocObjects.RhinoObject obj in args.RhinoObjects){
        if(obj.ObjectType == Rhino.DocObjects.ObjectType.Brep){
          try{
            ComponentIndex[] ci = obj.GetSelectedSubObjects();
            if(ci != null & ci.Length > 0){
              foreach(ComponentIndex c in ci){
                if(c.ComponentIndexType == ComponentIndexType.BrepFace){
                  geo = ((Rhino.Geometry.GeometryBase) ((Brep) obj.Geometry).Faces[c.Index]);
          catch{}
          this.Component.ExpireSolution(true);
    else{
Thanks!
And I found the type descriptor for the indices too, ComponentIndexType.
