I need to import 3D shp files created by the ESRI software.
Does anyone know a good way to get this done ?
thank you for your help
Andreas
Andreas
Just searching Food4Rhino for shape shp shows there are two plugins that should let you do that: Meerkat and @it.
thanks Wim… i will check it out!
meerkat seems to work only for 2d file as far as i understand, so that won’t work…
still testing @it, but no success so far…
is there maybe a 3rd party conversion tool to get these horrible shape files into something like 3ds or dwg or obj…?
best
Andreas
You should be able to import them into QGIS (open source) and then export them as something Rhino-usable… Otherwise, there is RhinoTerrain, but that is rather expensive… --Mitch
It would be better if Rhino could read shapefiles directly. I see Rhino used for urban planning more and more…
We thought it might be cool if Rhino ran inside ARCGIS: GitHub - nicoazel/ArcRhino: AECTech Hackathon 🦏 Rhino.Inside project for 🌎 ESRI ArcGIS Pro · GitHub. DOne right this could give everyone the flexibility to control the transfer.
There is also You can download shapefiles of OpenStreetMap from BBBike. A workflow is to download an OSM file directly from OpenStreetMap and import the data using Elk along with USGS elevation data for topos.
Yes but this requires arcgis. I don’t need it , i won’t install a software just to convert a file
Sometimes shapefiles are provided by municipalities, those files include future proposals, additional data which is not on OpenStreetMap.
Elk is very unreliable. In many situations those files are very large in size.
Much more easy is to have shp import in rhino. It is an open format, no?
Hi Scott, I was wondering how feasible it would be to integrate Rhino.Inside into QGIS? ArcGIS is great but many find the cost of licencing prohibitive. There seems to be a gap for integrating GIS and the AEC tool ecosystem, Rhino.Inside.QGIS could make a big difference I feel.
Because QGIS does not have .net SDK running Rhino.inside gets tricky. Much of the problem is related to this discussion: https://gis.stackexchange.com/questions/64479/is-it-possible-to-use-dotnet-to-show-a-qgis-map
But it does not mean it is impossible. I might first figure out if rhino.inside can be loaded thru the QMap Python interface. Although no interface would show, there might be a lot you could do with geometry and files.
I would pose a question to the rhino.inside forum here to work thru the possibilities. Our developers may have a better idea on how feasible it is.
Given how ubiquitous shapefiles are for boundaries provided by governing authorities, is it too much trouble to support import into Rhino? Anything I design will have to fit within a boundary and some boundaries are too idiosyncratic to rebuild from scratch, even with unlimited time. Building maps from layers from different sources would be a lot nicer in Rhino, which actually has a scale, than in vector art tools (scale? what scale?).
Hi -
You could try Grasshopper to import Shapefiles. That doesn’t seem to work with all formats of those files but you could then also try Grasshopper plug-ins such as Heron or ShrimpGIS.
