Hello hello helpfull community !
I’m trying to use the compute.appserver and I’m trying to load a grasshopper importing a .obj file
But when I do that some error appears :
System.NullReferenceException: La référence d’objet n’est pas définie à une instance d’un objet.
à Pancake.Component.pcNativeImport.SolveInstance(IGH_DataAccess DA)
à Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it)
I define an absolute Path (C:/Users/object/myObject.obj) but maybe it’s not the good way to do it ?
I read the post here (which is a good trick ) : Compute.rhino3d.appserver partially empty output when using THREE.JS STL loader - #8 by martinborst1
I wonder if there’s is an other solution to load .obj file in .gh definition which will work in compute.appserver ?
the grasshopper file is very simple if you want to try it :
import_obj_compute_appserver.gh (9.7 KB)
Thank’s
