Object not loading ... Need help to see what's wrong with the GH file
Limited GH knowledge but working on the API stack …
I have a GH file that I’m uploading, it works on the rhino8 software/ui itself.
However when I try to load the same via the appserver/compute.rhino suite I get ‘No rhino objects to load!’ on the appserver definitions.hbs script.
I’m not really sure whats missing. I have installed the plugins etc as errors used to come up related to that. Now it seems to fail silently…
Sincerely,
Tanil
HoneyTanil.gh (17.5 KB)
not sure if this is the error, but you’re not returning anything from your .gh file.
You can return objects like this:
