How To import a Layout From another Rhino File using Rhino Common
I was wondering, it there is a way of importing a Layout from another Rhino File into the current doc using Rhino Common (including the details on that layout).
Or Do I have to use the Rhino command “-_ImportLayout”
Thanks
Martin
Hi Martin,
It`s probably the easiest way. Here is one example, works if you know the page number…
greetings,
c.
