Is it possible to get an object’s style name from the VA api ?
I have seen a GetStyleName(GUID) in the API but how can i get the GUID to pass here ?
I found the GetWallStyleId(string name) but what is the name in this call ? Is it the style name ? (in this cas i’m wrong )
Thanks,
Georges
enric
(Enric Marquès)
October 8, 2021, 1:45pm
2
Hi @gehairing ,
You first need to get the style id from the object, using the method GetProductStyle
. Then, you can get the style name using the returned id:
class Sample
public static string GetObjectStyleName(RhinoObject rhinoObject)
Guid objectId = rhinoObject.Id;
if (objectId != Guid.Empty)
if (va.IsProduct(objectId))
Guid styleId = GetProductStyle(rhinoObject.Id);
if (styleId != Guid.Empty)
return GetStyleName(styleId);
return "";
Regards,
Enric
Thanks a lot Enric.
I’ll try this out next week.
Georges
