How to get rid of this dialog box when save rhino 4 file into rhino 5
I’m newbie in rhinoscript
I use -Savesmall in python script, how to get rid of this.
Thanks,
Should disappear if you change the default version of the files.
i dont understand how to do that
Hello - if you open a V4 file in V5 and Save changes, you get this. If you use
-Save, with a dash in front, all interaction is at the command line and dialogs are suppressed. (Unless you click Browse)
-Pascasl
that is -save result when save v4 to v5
I assumed like other applications there is an option to set which version should be considered as default when clicking on ‘save’ button. But that appears as a flaw in Rhino.
Perhaps it should be added here:
