Once I run it wont let me select anything to isolate and just goes straight to the convert command and then run the isolate at the end. Is there a way to nest multiple commands in a macro without them interfering with each other.
Hi Pascal, thank you for looking into this for me. I tried running the macro by pre-selecting the curves, when I do that it doesn’t run the isolate at all. I get a “Unknown command: $$Isolate$$” in the command line
