I am actually using R6 and I have a problem from Grasshopper, I’d llike to applicate fillet on my surface selected, and I had to call Fillet edges fonction from Gras to obtain this result
Though looking at the image you are trying to build I think you want something more like this as the fillet edge component goes both ways from the centre of the edge. Note with this workflow I have not worked out the maths to set the radius. You would need to do this.
Also showed you how I would code the first part. I did not have the plug-ins so only answered the question part of the code so you will need to merge the codes.
I want now to generate Lattice form from my cyndrical surface, the problem is when I select it the Conform surface axis from Intralice not working like I want, here are my surface:
