This is model of a Yamaha p-115. I’m almost complete, but the line in the center of the curved face really bothers me. I tried to fix it several times through several methods. Extracting/extruding an edge curve then trimming. Extracting an isocurve and doing the same. Nothing worked. (I believe it is something with the original curve) Eventually I just continued along as it does not show in rendered view. Still, it bothers me to no end that could not solve it, and I know its even more difficult now as I’ve already filleted the edges, (Is there such a thing a as “Un-fillet”?) but if anyone has thoughts or suggestions.
Problem area.
I’m not getting that to work. As I mentioned, I think the is something wrong with the original curve. If you highlight the surface and zoom in to the bottom you can see that the isocurve is all wacky. I was wondering if this is a problem?
Thank you for your efforts, but I’m confused as I did similar things.
I exploded removed the offending face. Then extruded the same Curve. However, the trimming did not work no matter which cutting objects. Even when I rejoined everything else as the cutting object.
Which edges you are merging exactly, I can’t tell from the pic. Perhaps that is my problem?
