Hi
I use component split brep multiple. After split I use List Item to check. There something wrong
with Index 0
With Index 1
I guess they should be in order.
How could I fix it?
P/s I follow this tutorial Rhino Grasshopper Modeling Kisefos Museum by BIG - YouTube
04.Rhino Grasshopper Modeling Kisefos Museum by BIG.3dm (7.2 MB)
04.Rhino Grasshopper Modeling Kisefos Museum by BIG.gh (24.2 KB)
I’m not using Pufferfish so I can’t check the entire definition.
You can sort the resulting Breps according to their Y-coordinates. You can add the file below to your definition.
sort_brep_centroids_y.gh (2.8 KB)
HS_Kim
3
I didn’t see your reference tutorial, but this could yield pretty much the same result for sure…
04.Rhino Grasshopper Modeling Kisefos Museum by BIG_re.gh (23.3 KB)
Thank @martinsiegrist It work well
Thank @HS_Kim Your method look interesting. I will try after finish this tutorial.
HS_Kim
6
? Did U download and check the file I’ve posted above?
RMB on Explode Tree and check the option “Match Outputs”…
Great. It work now.
Yes I open your file and try to replicate it from scratch. (the way I learn)
Thank
Travis
