I have this extruded part with several thousand edges. How do I add a working radius to just the outer edges? I tried displaying points on the edge curve but each point is a different number.
I suggest:
1 identify features of these selected edges
2 use gh code to get index of these edges, by filtering all edges using feature found in 1
3 it’s filleting time!
This time, I have a pattern of holes with variable radii, and I’m trying to add a variable fillet to each row of those. So all the larger holes should have one value and it tapers as you get to the smaller holes.
@martinsiegrist I managed to isolate the right edges using your earlier definition but now struggling to get the fillet to work.
grille_variable.gh (26.0 KB) @martinsiegrist Dont want a set radius, ill have to play around. @magicteddy Haha, I had no idea GH requires such complex logic for a simple fillet. Hopefully, they’ll add a fillet option in the extrude operator itself
@wagh.arnav you can make a selection with a cull pattern, like attached, but you will need a cleaner definition of your geometry to make this anything useful, since you can quickly run into troubles like these:
@wagh.arnav im a bit surprised you marked mine as solution. I think Martins’ is the more organized/controlled way to select the right items to fillet.
That being said, there is one more way to select the edges of the round holes, if they are closed curves, you could filter them based on that aspect.
My example was merely to show you one way to make a selection based criteria you set.
