How to export files into the Maxwell Render Studio
I want to solve this issue, how to export files into the Maxwell Render Studio?
I tried to use .obj .fbx .dae .3ds but it’s not working correctly.
Someone who using Maxwell Render here?
Thanks!
FWIW, I use Maxwell but through the Rhino plugin on Windows.
The formats that you list should work - have you tried with a very simple scene like a single box for example?
Perhaps @jdhill has some ideas…
Thanks for reply!
I understand, but this is the problem, plugin is only for windows.
These formats works, but for example, in .obj I have a issue with scale. Ok, you could say, for some scene it’s not important but for some it is.
I solved this in Maxwell by changing the scale settings for the whole object on 0,001 for now.
.fbx was good in scale, in groups with “subgroups” but the camera was blurry and I could not make any change in camera settings to fix it.
.3ds. This format does not remember the group from Rhino and .dae is not good too.
It’s a simple scene (screen), car toy but this happens in every models.
I think the .obj format is best for me if I change some values.
Hi everyone, it’s possibile for you ti share the Rhinoceros plugin of Maxwell render because I can’t find it anymore?
Thanks a lot
Hi @illo76,
You’ll find it here: Next Limit - Webshop
