I’m pretty new with this, but I’ve searched a lot to find a way to export Rhino 3dm file to Solidworks one, and I couldn’t find a solution. Is there a way to export the attached file in something I can use in Solidworks? Export as only a shape will do the job too.
you are hosed then…solidworks has awful mesh integration/ no mesh tools. Best bet is to import it as reference objects and rebuild it from scratch in SW-
Is there a reason you need it in solidworks? What are you trying to do? there are a ton of poly modelers out there that can do just about anything you need from texturing to tooling right off the mesh.
Well, I want to build a tube frame for this formula car. It is gonna be a real build, no just a 3D model. To import it as a reference object would do the job, but how to import it ? And yes, there are lots of models, but those I found as the best for the case, and probably the best looking for such a car.
Draw the profile of the tube frame skeleton then point edit (F10) in plan view to get the right width. Once you’ve got a few items in you can snap to them and it gets much easier.
Heck, it might be easier to draw a polysurface generally like you want then dupedge and draw on surfaces to get the skeleton.
Thinking about it some more, another way is to just do your outer frame in rhino, get it into SW then 3D sketch the rest there parametrically.
Draw the linear sections and planer arc sections first, then fill in the rest. Doing so makes it easier to visualize the remainder, and use tools such as arc blend to join the sections. You need to consider what you can get tubing to do as well.
**…or…**perhaps toss the computer and consider a career in retail. It’s easier…
Just kidding. In all seriousness, keep at it. You’ll get it!
If you can imagine how your 3D curve might look from, say the top and side, or whatever 2 viewports would give the best representation, you might try Curve From 2 Views. Quick win!
I just want to make the outer frame, yes. To get the dimensions and then do the rest of the job in SW. I do the curve but I only succeed to do it in 2 dimensions. When I try to bend it on the 3rd dimension, I can’t or at least I don’t know which tool to use it for this.
