How to define working plane by object?
There is a command “_CPlane_Object” to do this.
I want to do this by calling function.
How can I do?
Vaker
How can I do?
Vaker
Is there a specific object type you want to generate this plane from? The _CPlane _Object command asks for user input for the object type and acts accordingly, eventually creating a Plane, and setting the construction plane of the viewport.
You’ll probably need to run: http://developer.rhino3d.com/api/RhinoCommonWin/html/Overload_Rhino_Display_RhinoViewport_SetConstructionPlane.htm
Which will take a Plane as an argument: http://developer.rhino3d.com/api/RhinoCommonWin/html/T_Rhino_Geometry_Plane.htm
How you set up this plane is up to you.
Hi Vaker,
To set a viewport’s construction plane, you’ll want to call CRhinoViewport::SetConstructionPlane().
The CPlane -> Object option allows you select a point, curve, surface, or clipping plane and then will set the active viewport’s construction plane based on what you’ve picked.
Here is an example:
I got it.
Thanks for your help.
Vaker
