Construction plane from closed curve profile
Can anybody help me how to create a CPlane from a closed curve in Python?
I would like to click on the profile, define the X axis of the CPlane and draw lines. After I finish the CPlane would jump back to the previous CPlane.
How far have you come so far?
quick n dirty pseudocode:
object = select object
rs.CurvePlane(object)
x_line = rs.GetLine()
x_tangent = rs.VectorCreate(x_line[1],x_line[0])
new_cplane = rs.PlaneFromFrame(plane.Origin,x_tangent,plane.YAxis) #tricky and might fail if axes align
current_cplane = rs.ViewCPlane()
rs.ViewCPlane(new_cplane)
do line drawing here
rs.ViewCPlane(current_cplane)
HTH
-WIllem
Thanks Willem,
I learnt a lot again. I think the plane.YAxis is not documented. We are not able to use as variable but in arguments is works.
I also have not tried the GetLine and ViewCPlane() yet. The name of ViewCPlane() is a little bit misleading. I thought it sets CPlane to the current view angle. Ha ha…
My solution would have been by Command method to run native Rhino command for CPlane.
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_Geometry_Plane_YAxis.htm
– Dale
Thanks Dale,
Does it mean, that we can use all of the properties of certain objects from RhinoCommon in IronPython?
Yes,
Have a look at these screenshots from the editor.
You can click at the position of the red dot to insert a breakpoint.
This will halt the script at that point and you can inspect the content of the current variables:
More to find on rhinocommon:
https://developer.rhino3d.com/api/RhinoCommon/html/N_Rhino.htm#!
search for plane for example:
A good way to explore working with rhino common in python is to insert breakpoints before a rhinoscript method and the step into the code:
if you click Step Into or F11
you will see what code is executed for rs.ViewCplane():
-Willem
It almost works. The rs.CurvePlane align to the vertical side of the geometry and not the horizontal. The vertical side is also not perpendicular to the horizontal one. I have to use plane.XAxis instead of plane.YAxis.
I need to transform the plane.
