How to cut geometry with a ring around the bottom
im trying to split this shape so its got a flat bottom, i tried using multipipe and then using mesh split but it doesnt completely cut along the box, i wouldnt be worried about the pattern being cut in half. then if possible have a ring connecting the edges where it was cut.
if possible i actually want it to be cut along the pattern so it has a roughly flat edge without cutting the pattern in half, kinda like this, but i dont know if thats possible
forgot to attach the gh file
Floret dome_JD_LD.gh (18.7 KB)
SubD are not mesh, you can do that
you are honestly a life saver, for this and the last time, thank you so much!
