How to create this "golden cube"
Hi I have these curves but can’t make the shape in one command.
I do it by dividing them and creating a surface through Surface from network of curves and then Mirror until I get the whole shape.
The problem is that for some reason the seams aren’t tangent and i get small peaks instead of a smooth surface. Can you do it seamlessly without dividing the curves? I attach the file bellow.
prueba.3dm (58.9 KB)
have you looked at _Railrevolve?
Rhinoceros Help - RailRevolve | Rhino 3-D modeling (mcneel.com)
See attached pls
I created a solid by extruding closed curve (red) in Z direction with both sides. Than fillet edges…
Hope that will help you
prueba_YA.3dm (257.9 KB)
Thank you guys, both ways worked great. Rail revolve it’s exactly what I needed :pray:
dear @Fernando_Ruiz
maybe check the exact shape of the planar top / bottom.
(and therefor define it with a second curve ?)
_railrevolve
will extend the shape of the quarter / half circle at the diagonal. (it will become a partly ellipse)
not sure if this is your design intention.
check the section in the diagonal. compare green and red curve:
Great attention to detail. That’s why i could’t get tangent seams before. It’s not really important in this case but many thanks for suggesting
