Hello, i’m trying to create extruded text but it keeps creating it vertically instead of horizontally.
Hi Mitch - planar curves will extrude normal to the curve plane by default; if multiuple planar curves, then if they are in parallel planes, the direction should be normal to those planes. If there are non-planar curves in the selection, or the curve planes are not all parallel, extrusion defaults to the construction plane normal.
To force a particular direction, use the Direction command line option.
