How to create equilateral triangle on a Sphere
How to create paneling grid on a sphere for the construction of a equilateral triangle on a Sphere.
Thanks
Have you looked at the Polyhedra plugin yet?
I think you could use a Geodesic Icosahedron.
I wanted to find a sphere made up by triangles with same shape and area. However, I couldn’t get it.
A sphere has the minimum surface area for a given volume. Any other shape will have a larger surface area for the same volume.
If I want to prepare cladding panels with one size only to fill the sphere. Is it possible by your plug-in program?
Yes it can be done with that plugin. But there are just a two options: https://en.wikipedia.org/wiki/Platonic_solid
Hope it helps.
There’s a limit … known to pythagoras thousands of years ago: There is only a small number of regular polyhedra. The icosahedron is the best you can do.
The work of Alain Lobel is highly relevant here. You might also consider implementing a constraint solver for this. Kangaroo2 and ShapeOp comes to mind. Both available for Rhino/Grasshopper.
