Hello!
Can you tell me if I can create a reinforcement mesh for a concrete element in Tekla using Grasshopper? I installed the T-Rex component for Grasshopper. But the T-Rex does not make it possible to create a reinforcement mesh. I can easily create a reinforcement mesh in Tekla. But I don’t understand if this is possible in the Grasshopper program.
Thank you for your attention!
Hi, the Mesh object type is not available in the GH-Tekla link. But you could create rebar groups instead, or then create a custom component with a rebar mesh and insert that from Grasshopper.
Cheers,
-b
Ok, thank you!
