How to create a command that selects multiple objects interactively?
Hello.
I recently started developing Rhino plug-in.
I would like to implement a command that allows the user to select multiple objects interactively, but it is difficult.
Below is the sample code of the Command class.
As the execution result, only “Select base object A” is output, and “Select target object B” is not output.
For some reason, the variables pointA and pointB contain exactly the same value.
using Rhino;
using Rhino.Commands;
using Rhino.Input;
using Rhino.Input.Custom;
using Rhino.Geometry;
public class GetRelativeCoordinatesCommand : Command
    public GetRelativeCoordinatesCommand()
        Instance = this;
    public static GetRelativeCoordinatesCommand Instance { get; private set; }
    public override string EnglishName => "GetRelativeCoordinates";
        ObjRef objARef = null;
        using (var getObject = new GetObject())
            getObject.SetCommandPrompt("Select base object A");
            getObject.SubObjectSelect = false;
            getObject.Get();
            if (getObject.CommandResult() != Result.Success)
                return getObject.CommandResult();
            objARef = getObject.Object(0);
        if (objARef == null)
            return Result.Failure;
        ObjRef objBRef = null;
            getObject.SetCommandPrompt("Select target object B");
            getObject.Get();
            objBRef = getObject.Object(0);
        if (objBRef == null)
        var pointA = objARef.Geometry().GetBoundingBox(true).Center;
        var pointB = objBRef.Geometry().GetBoundingBox(true).Center;
        var relativeVector = pointB - pointA;
        RhinoApp.WriteLine($"Relative Coordinates from A to B: X: {relativeVector.X}, Y: {relativeVector.Y}, Z: {relativeVector.Z}");
        return Result.Success;
Environment
  • .NET7
  • Windows11
  • Rhino8
Welcome! You need to programmatically unselect the first selected object before the second selection. Otherwise the second selection is done immediately and both variables point to the same object like you experienced. This is done easiest with doc.Objects.UnselectAll()
https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.tables.objecttable/unselectall
Ah, I see!
It worked when I ran UnselectAll()!
Thanks @menno !
