I am trying to enable multiple objects to be selected w/ command line options & as soon as the command line options change, the selection switched to one object from multiple, code below:
import Rhino
import scriptcontext
def CommandLineOptions():
# For this example we will use a GetPoint class, but all of the custom
# "Get" classes support command line options.
gp = Rhino.Input.Custom.GetObject()
gp.SetCommandPrompt("Get Points & curves")
gFilter = Rhino.DocObjects.ObjectType.Point
gFilter |= Rhino.DocObjects.ObjectType.Curve
gp.GeometryFilter = gFilter
# set up the options
intOption = Rhino.Input.Custom.OptionInteger(1, 1, 99)
dblOption = Rhino.Input.Custom.OptionDouble(2.2, 0, 99.9)
boolOption = Rhino.Input.Custom.OptionToggle(True, "Off", "On")
listValues = "Item0", "Item1", "Item2", "Item3", "Item4"
gp.AddOptionInteger("Integer", intOption)
gp.AddOptionDouble("Double", dblOption)
gp.AddOptionToggle("Boolean", boolOption)
listIndex = 3
opList = gp.AddOptionList("List", listValues, listIndex)
gp.GetMultiple(1, 0)
while True:
# perform the get operation. This will prompt the user to
# input a point, but also allow for command line options
# defined above
get_rc = gp.Get()
ids = [gp.Object(i).ObjectId for i in range(gp.ObjectCount)]
if gp.CommandResult()!=Rhino.Commands.Result.Success:
return gp.CommandResult()
#if len(ids)>0:
if get_rc!=Rhino.Input.GetResult.Point:
#point = gp.Point()
#scriptcontext.doc.Objects.AddPoint(point)
#scriptcontext.doc.Views.Redraw()
print "Command line option values are"
print " Integer =", intOption.CurrentValue
print " Double =", dblOption.CurrentValue
print " Boolean =", boolOption.CurrentValue
print " List =", listValues[listIndex]
elif get_rc==Rhino.Input.GetResult.Option:
#if gp.OptionIndex()==opList:
#listIndex = gp.Option().CurrentListOptionIndex
continue
break
return Rhino.Commands.Result.Success
if __name__ == "__main__":
Sorry for the trouble.
