how to copy color from wireframe, shaded mode to render mode, I use rhino import step file and export skp but have no color, are there some commands to copy color from wireframe, shaded mode to render mode instead of manually set color ?
hi @fuidasnk that can be done with
SynchronizeRenderColors
It become all black but thanks for fast answering
Hi -
If you can share a simple STEP file we can take a look.
Note that SynchronizeRenderColors
will assign a single material to the object’s layers. If objects or sub-objects override the layer color, this single layer material might not be what’s expected.
here, thanks for checking and tolerate newbie
The King’s Castle.STEP (18.1 MB)
You’ll need to explode your model to get the underlying colors of the STEP file.
I suggest than grouping everything into layers by desired color. You can use SELECT->Select by color. It will make your life easier.
I exploded your model twice and only than you can see the color in this panel. You’ll than need to assign that color to the layer and only than will this command work
Maybe some of the more experienced guys know if you can get the output of the color prior exploding. Perhaps using the color selection filter also.
Example:
