All the time, i need to convert several file (.igs) to (.wrl), and i waste a lot of time, it’s possible to convert all file in one time, and how to do it ? or more efficiently.
Actually i need to open the file on rhino5.0 and save it as (.wrl). "so long when you have many files.
Thank you !! you respond so quickly !!!
I tried it, i wasn’t thinking it’s possible to code on rhinoceros.
You find this on internet ? or you know how to code ?
I composed it from other scripts I had in my archives, because most of the time working with files follows the same kind of patterns. I’m by no means an expert programmer, there are far more experienced programmers on this forum, but I know enough for making these kind of simple things.
If you want to learn using python on Rhino, a good start is https://www.rhino3d.com/download/IronPython/5.0/RhinoPython101
Thank you @pascal.
I have Rhino7 installed on Windows 10. I took the script above and saved it as RhinoScript1.py and then tried to run it in command line … and got following error
ImportError: No module named Rhino
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 4-7-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P520 (NVidia) Memory: 2GB, Driver date: 4-5-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.30
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-5-2021
Driver Version: 27.21.14.6230
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
