Default export igs, 3dm, stl
Hi everybody,
This code uses to default import igs, stl ,3dm
anyone can edit it to export code ??
-runscript
(Sub import
Dim strFolder1,strFilename1
Dim objFso,objStream,FileDate,FlieExist
Dim zs,zt,zn
strFolder1 = Rhino.ExeFolder
Set objFSO = CreateObject(“Scripting.FileSystemObject”)
Dim strFolder,typed
Dim Filename,f,fc,strFilename
Typed=Rhino.GetString (“Type: 1, Iges ; 2, Stl ; 3, 3dm”,1)
If typed=1 Then
fc=Rhino.OpenFileNames(“Import”, “Igs Files ( *.igs)|* .igs|3dm( *.3dm)|* .3dm|All Files ( *.* )| *.* ||”)
If Not IsArray(fc) Then Exit Sub
ElseIf typed=2 Then
fc=Rhino.OpenFileNames(“Import”, “Stl Files ( *.stl)|* .stl|3dm( *.3dm)|* .3dm|All Files ( *.* )| *.* ||”)
ElseIf typed=3 Then
fc=Rhino.OpenFileNames(“Import”, “3dm Files ( *.3dm)|* .3dm|3dm( *.3dm)|* .3dm|All Files ( *.* )| *.* ||”)
End If
For Each strFilename In fc
If Not IsNull(strFilename) Then
Rhino.Command “_-import " & “””" & strFilename & “”"",vbFalse
End If
filename=UCase(OBJfso.getbasename(strFilename))
Dim arrobjects,currcentlayer
Dim arrLayers, strLayer
Dim llayer
arrObjects = Rhino.SelectedObjects
currcentlayer=Rhino.CurrentLayer
arrLayers = Rhino.LayerNames
If IsArray(arrLayers) Then
For Each strLayer In arrLayers
If strlayer=Filename Then
filename=filename&"-2"
Else
filename=filename
End If
Rhino.AddLayer(Filename)
Rhino.Layercolor (Filename),RGB(127,255,191)
Rhino.ObjectLayer arrObjects ,Filename
If Rhino.IsLayerEmpty(strLayer)And strlayer<>currcentlayer Then
Rhino.DeleteLayer (strLayer)
End If
Next
Rhino.command"noecho sellast group pause"
Rhino.command"_SetView _World _Perspective _Zoom _Extents"
End If
Set arrObjects = Nothing
Rhino.UnselectAllObjects
Next
Set objFSO=Nothing
End Sub
import
