How to polysurface convert single surface or mesh convert single surface , what is procedure, I am tried polysurface untrim surface and merge surfaces ,but I didn’t get result , please tell me
mesh to surface.3dm (444.3 KB)
Hello - in general, there is no way to ‘convert’ - if you can post an example file, and explain why it is you would like to have a single surface, it may be possible to help.
You can select a surface and type dup border > planar srf
mesh into a polysrf type mesh to nurbs > sel mesh > delete (to remove the duplication of objects)
Is this what you mean?
Hello- use the upload icon in your response.
Please export the relevant objects to a new file and post that, if your file is large.
Hello - in this case you can build a single surface using the mesh as reference but there is no ‘convert’. I’ll make something shortly to get you started.
how to do that
