Hi guys!
I’m trying to control the UV distance, the distance I want to be 3.50m. between each module.
Is there any way to control this? All I can think is, bake and then use Scale1D in Rhino.
Hi guys!
Hi @mauriciovb
Have you tried generating the UV distance based on the size? Of course this works only when you have values that divide exactly. So, in a way, it also helps to cross-check your dimensions.
Example:
U Parameter = 15m / 1.5m => 10
V Parameter = 12m / 1.5m => 8
P.S. You can also use the Scale NU (Scale Non-Uniform) component.
Kaushik LS
Chennai, IN
Thanks for the answer! It worked your solution btw
