How to control text wrap in Rhino 6?
Or I might have had a very long day or this is actually not intuitive…
How do I control the text wrapping of the “Text” command in Rhino 6? Before you would double click the text and check “Wrap” and move the window around to control it, but now that option is no longer available…
Thanks
Hello - turn on control points for the text block - you can drag the right hand one around.
Ohhh, okay, cool!
I disabled the default options of having control points for curves turned on, I guess that hid those control points as well.
Correction: Its for curves, lights and annotations… Maybe an option to hide only Curves control points can be added in the future?
Thanks Pascal!
Or if you don’t like the automatic control points, select your text and tap F10.
