I’m searching for a way to change the color of the rhino default materials.
Since the ‘new’ V-ray release, last service pack included, i’ve been experiencing problems with materials and their consistency. Materials in the scene have the correct material name assigned to them nevertheless it very often happens that the link between v-ray and those geometries is lost - it seems that the rhino purge material command is breaking links randomly?!
After a purge material command i’m sometimes left with either parts of the geometries set to the rhino default material - which is white or with the problem mentioned above which is a broken link between rhino material table and v-ray material editor?!.
Hence, could someone enlighten me on the topic of changing the default rhino material color to let’s say pink?
Thank you in advance!
