My clipping plane has a really long shaft length? Where is the option to shorten it? Thanks
Hi -
There is no such option.
The current state is the result of you scaling the clipping plane. You could scale it back to the original size or create a new clipping plane that has the intended size from the start.
oh ok. I’ll consider it as a feature wish then
Hi -
In that case, you might want to describe what problem this would fix.
In my case, I have a lot of clipping planes in my architecture models and all the lines are really long and cut across the viewport at every angle. It’s visually confusing. I feel like its one of those cases where people would not guess the solution easily. Because I was tweaking everywhere in options and viewport options, and turning on the control point seemed to do something but not really working. I did spend a ton of time trying to figure it out but there are just no such options as mentioned ![]()
Is there a sub-menu option somewhere to scale it back to the original size? Maybe an option can save other users some times to figure out the same problem next time
I have the same problem but I use this macro to replace ClippingPlane and matchproperties. It is not a one click solution but it is a bit faster…
_-ClippingPlane 3Point _Pause _Pause _Pause
_SelNone _Sellast
_-MatchProperties
/Fredrik
Note that clipping planes in Rhino 8 no longer have such line…
Agreed. This would be nice. Everything else in Rhino at least has control points or similar. Not sure why clipping planes don’t.
True for 8. I’m sticking with Rhino 7 until a few 8 bugs are squashed, most importantly the layer dialog lag, the worst of the bunch and a trust killer.
