Is it possible to change a block’s base orientation that was (carelessly) made in place relative to the item? I was tidying up a file that has some blocks that, once I want to replace it with another block item, gets a wrong orientation, because the to be replaced block has its base orientation not aligned with the object(s).
Thanks, this workaround might work indeed. Still I hope that I can fix it in the block in question. Otherwise I need to use your workaround first to make a replacement block, fix the block in question and do another replace block, if you understand what I mean.
I very much support this note/request. It seems like a simple way to handle this would be to add an option to “UseCurrentCPlane” when setting the block, in which case the user could easily set a CPlane to the desired orientation for the block
