I’m barely new to scripting and programming. I was trying to develop a script to create different surfaces automatic for my graduate project. In order for the script to be completed, I need to use the squish command. I don’t know how to call it, I was trying to use UnrollSrf but I need more accuracy. Is it possible to call the command?
EDIT: only after posting I realized you are not programming in Python.
Still I leave my answer up as it might still be of use to OP or others.
I extracted the squish code out of our library.
Some lines specific for our workflow I purged so maybe that broke something, but I think it will get you on your way:
def squish_macro(objs):
run squish command on input geometry and return result
squish command options:
SplitSeams=Yes
PreserveBoundary=No
Deformation=Free
Material=Floppy
Outside=Up
Decorate=No
Deformation
Choose an option depending on your bias for stretching or compressing, and the ability to specify custom deformation settings.
Free: No preference for compression or stretching.
StretchMostly: Strong bias for expansion when the pattern is deformed into the 3-D shape.
StretchOnly: Absolutely no compression when the pattern is deformed into the 3-D shape.
CompressMostly: Strong bias for compression when the pattern is deformed into the 3-D shape.
CompressOnly: Absolutely no expansion when the pattern is deformed into the 3-D shape.
SQUISH HELP FILE:
Custom deformations.
The Custom option lets you set the parameters used by the custom deformations. There are four parameters you can set.
BndStretch
BndCompress
InteriorStretch
InteriorCompress
The default value for these parameters is 1 and they can be set to any positive number.
A larger value reduces the amount of the specified deformation compared to what happens
when all four parameters are equal.
For example, if you want to severely limit interior expansion, you could do something like:
BndStretch=1
BndCompress=1
InteriorStretch=1
InteriorCompress=100
If you want to preserve boundary lengths you could use the settings:
BndStretch=10
BndCompress=10
InteriorStretch=1
InteriorCompress=1
custom_1 = 'BndStretch=10 BndCompress=10 InteriorStretch=1 InteriorCompress=1 '
cmd_str = 'Squish ' \
'SplitSeams=Yes ' \
'PreserveBoundary=Yes ' \
'Deformation CustomSetup A {} _Enter ' \
'Material=Rigid ' \
'Outside=Up ' \
'Decorate=No ' \
'Enter'
cmd_str = cmd_str.format(custom_1)
rs.UnselectAllObjects()
rs.SelectObjects(objs)
rc = rs.Command(cmd_str,echo=False)
if rc:
result = rs.LastCreatedObjects()
return result
