How to Align two objects in 3D
How do you align two objects in 3 dimensions?
I need to align multiple instances of this ring to these poles all at different angles. How can I copy them and snap them to the different angles?
I am sure there is a quicker way to do it compared to rotating it in 3 separate planar views.
Thanks in advance
BoxEdit will let you enter XYZ rotations.
Also:
You can also use the Orient3Pt command
Rhinoceros Help - Orient3Pt | Rhino 3-D modeling (mcneel.com)
