Hello, please see the attached GH cluster with internalized data.
I have simplified this a lot from the project that I am working on- I need values applied to points to use as weights for something else. I have several circles that each test a grid of points for inclusion and then, using the center point of these circles, apply a 0 to 1 Luchbox attractor to the points. So the points closest to the center are 0, farthest away are 1. This is working well:
In some cases these circles and attractor fields overlap so that points in the overlapping region are getting assigned values from more than one attractor:
What I want is for the overlapping values to add together so the total number of values I have is equal to the number of points I am testing.
My thought is that I somehow need to compare the branches of the value tree to each other or to the branches of the tested points and identify the overlapping values, then add them together. I can’t seem to come up with a solution to do this.
If anyone has suggestions on how to do this, or ideas for another way to do what I am doing, I would be very grateful.
Thank you
Overlapping_Attractors.ghcluster (3.9 KB)
